elektryk
I have to design PCB for some kind of computer. I will have 4 layers without burried via. It has to fulfil some EMC rules. I have designed it with one groud plane (inside board) divided to two areas (digita and analog groud). Top and bottom layers will be covered with ground planes at all free space. The question is what is better for conecting ground for chip (high scale integrated, with lot of ground pins). I have two option, both with positive and negative consequences.
:arrow: via to ground plane
+short conection to ground
-current loop in ground (via-ground plane-via- another ground plane)
:arrow: long conection by "external" ground layers (on bottom and top layer)
+ no "holes" in internal ground plane
+ no current loops in ground
- high impedance in ground connections
