vhdl to verilog code convert
conmourtz
Member level 1
Member level 1
Volos, Greece
Hello there. Could anyone help me with translate this vhdl code to veriolog code?
Thanks in advance.
it is about 3 state machines. i know how to convert one state machine from vhdl to verilog but with 3 i cannot figure out what the states will be.
type tx_sequence is (high_setup, high_hold, oneus, low_setup, low_hold, fortyus, done);
signal tx_state : tx_sequence := done;
signal tx_byte : bit_vector(7 downto 0);
signal tx_init : bit := '0';
type init_sequence is (idle, fifteenms, one, two, three, four, five, six, seven, eight, done);
signal init_state : init_sequence := idle;
signal init_init, init_done : bit := '0';
signal i : integer range 0 to 750000 := 0;
signal i2 : integer range 0 to 2000 := 0;
signal i3 : integer range 0 to 82000 := 0;
signal SF_D0, SF_D1 : bit_vector(3 downto 0);
signal LCD_E0, LCD_E1 : bit;
signal mux : bit;
type display_state is (init, function_set, entry_set, set_display, clr_display, pause, set_addr, char_f, char_p, char_g,
char_a, done);
signal cur_state : display_state := init;
