VHDL simulating a clock that doesn't run all the time
shaiko
Advanced Member level 5
Hello,
Signal x is a simulated clock that's defined as follows:
signal x : std_logic := '0' ;
x <= not x after 10ns ;
Suppose, I want x to start running after 100ns and stop after 1000ns.
The obvious solution will be to mux it...my question:
Is there a simple simulation syntax that allows to do that without using a mux?
You can use this.
x <= '0', not x after 100 ns, '0' after 1000 ns;
That wont make a clock, that will just set it high for 900 ns.
The easiest option is a mud like you suggested, or a process with control loops.
Code VHDL - [expand]
8
9
10
11
12
Process
Begin
  input <= '0';
  wait for 100ns;
  for I in 1 to 90 loop
    input <= not input;
    wait for 10 ns;
  end loop;
 input <= '0';
End process;
Reactions: shaiko
    shaiko
