tarek-
Newbie level 6
bad synchronous description
I have written a 4-bit ALU with CCR in VHDL, but when I try to obtain the Synthesis Report in Xilinx ISE 9.2i I get this error:
line 39: Signal C cannot be synthesized, bad synchronous description.
Line 39 is: " PROCESS(s, CLK) IS"
The code passes the syntax check and the testbench provides the correct waveforms. The Xilinx documentation on this error does help. I tried replacing the nested IF statements with the bottom block of code to determine the state of the CCR but I get more errors.
Any suggestions are appreciated.
edit: I found that removing the clock fixes the error, but i need this program to have a clock. The xilinx doc mentioned something about 'EVENT and IF statements but I didn't understand.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ALU4bit is
Port ( x : in STD_LOGIC_VECTOR (3 downto 0);
y : in STD_LOGIC_VECTOR (3 downto 0);
s : in STD_LOGIC_VECTOR (3 downto 0);
CLK : in STD_LOGIC;
V, N, Z, C : out STD_LOGIC;
f : out STD_LOGIC_VECTOR (3 downto 0));
-- SEV_SEG: out STD_LOGIC_VECTOR (7 downto 1));
end ALU4bit;
architecture Behavioral of ALU4bit is
begin
PROCESS(s, CLK) IS
VARIABLE temp, carry: STD_LOGIC_VECTOR(4 DOWNTO 0); -- extra bit is for Cout in arithmetic operations
VARIABLE A: STD_LOGIC_VECTOR(3 DOWNTO 0) := x;
VARIABLE B: STD_LOGIC_VECTOR(3 DOWNTO 0) := y;
VARIABLE k, sub: STD_LOGIC := '0';
BEGIN
-- initialize variables and outputs
C <= '0';
V <= '0';
N <= '0';
Z <= '0';
sub := '0';
carry(4 downto 0) := "XXXXX";
IF (CLK = '1' AND CLK'event) THEN
CASE s IS
-- arithmetic operations: s(3) = 0
WHEN "0000" =>
temp := ('0' & A); -- transfer x to temp
WHEN "0001" =>
temp := ('0' & A)+1; -- increment x by 1
WHEN "0010" =>
temp := ('0' & A)+B; -- add y to x
WHEN "0011" =>
temp := ('0' & A)+B+1; -- add y and Cin to x
WHEN "0100" =>
B := NOT B;
temp := ('0' & A)+ B; -- subtract y from x (one's complement subtraction)
sub := '1';
WHEN "0101" =>
B := NOT B;
temp := ('0' & A)+ B +1; -- subtract y from x and increment (two's complement subtraction)
sub := '1';
WHEN "0110" =>
temp := ('0' & A) - 1; -- decrement x
sub := '1';
WHEN "0111" =>
temp := ('0' & B); -- transfer y to temp
-- logical operations: s(3) = 1
WHEN "1000" =>
temp := NOT ('0' & B); -- invert y
WHEN "1001" =>
temp := ('0' & (A NAND B)); -- logical nand of x and y
WHEN "1010" =>
temp := ('0' & (A NOR B)); -- logical nor of x and y
WHEN "1011" =>
temp := ('0' & (A XNOR B)); -- logical xnor of x and y
WHEN "1100" =>
temp := ('0' & (A XOR B)); -- logical xor of x and y
WHEN "1101" =>
temp := ('0' & (A OR B)); -- logical or of x and y
WHEN "1110" =>
temp := ('0' & (A AND B)); -- logical and of x and y
WHEN OTHERS =>
temp := NOT ('0' & A); -- invert x
END CASE;
-- output assignment
IF s(3) = '0' THEN -- only consider CCR in arithmetic mode
-- determine negative bit, N
IF temp(3) = '1' THEN
N <= '1';
END IF;
-- determine overflow bit, V
carry(0) := '0';
for k in 1 to 4 loop
carry(k) := (A(k-1) AND B(k-1)) OR (carry(k-1) AND (A(k-1) XOR B(k-1)));
end loop;
IF (carry(4) XOR carry (3)) = '1' THEN
V <= '1';
END IF;
-- determine zero bit, Z
IF temp(3 downto 0) = "0000" THEN
Z <= '1';
END IF;
-- determine carry bit, C
IF ((sub = '1' AND y > x) OR (sub = '0' AND temp(4) = '1')) THEN
C <= '1';
END IF;
END IF;
-- determine output, f
f <= temp(3 downto 0);
ELSE -- When CLK is low, give garbage output
f <= "XXXX";
C <= 'X';
V <= 'X';
N <= 'X';
Z <= 'X';
END IF;
END PROCESS;
END Behavioral;
carry(0) := '0';
end loop;
V <= '1' WHEN (carry(4) XOR carry (3)) = '1' ELSE '0';
N <= '1' WHEN temp(3) = '1' ELSE '0';
Z <= '1' WHEN temp(3 downto 0) = "0000" ELSE '0';
C <= '1' WHEN ((sub = '1' AND y > x) OR (sub = '0' AND temp(4) = '1')) ELSE '0';
