Aya2002
Hi friends,
I am designing a FIFO handler but I face an error message in the If statement. Part of my code is:
the error message is: Error (10500): VHDL syntax error at FIFO_Handler.vhd(25) near text "If"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
I think my code is now wrong
what is your opinion?
Thank you for your help
library ieee;
use ieee.std_logic_1164.all;
-- FIFO Handler
Entity FIFO_Handler IS
Port(Rx_Ready : in std_logic;
Data : in std_logic_vector(7 downto 0);
Tx_Req : out std_logic;
Rd_Req : out std_logic;
FIFO_clk : out std_logic;
Wr_Req : out std_logic;
Tx_Data : out std_logic_vector(7 downto 0)
End FIFO_Handler;
Architecture FIFO_Handler_atl OF FIFO_Handler IS
Signal Rx_Req : std_logic;
Signal Rec : std_logic ;
signal Temp_Reg : std_logic_vector(7 downto 0);
-- constant delay : Time;
Begin
-- delay := 10 ns;
Rx_Req <= '1';
Rec <= '0';
If (Rx_Req = '1') Then
Wr_Req <= '1';
FIFO_clk <= '1';
-- WAIT FOR 10 us;
FIFO_clk <= '0';
Wr_Req <= '0';
Rec <= '1';
End if;
end FIFO_Handler_atl;
