VHDL Error: cannot determine exact overloaded matching definition for "="
Rimon Selim
Newbie level 2
Newbie level 2
ERROR:HDLCompiler:1731 - "C:/Xilinx/Processor/alu32.vhd" Line 87: found '0' definitions of operator "=", cannot determine exact overloaded matching definition for "="
I am getting this error on all of the lines with "="
I am using a case and here are the lines where the error comes up:
Code VHDL - [expand]
when (alu_op="1011") =>
            when (alu_op="0001" or alu_op="0010" or alu_op="0101" or
                            alu_op="0110" or alu_op="0111" or alu_op="1000") =>
            when (alu_op = "0011") =>
Full Code:
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
use work.c31L_pack.all;
entity alu32 is
        port( RI : in std_logic;
                a_alu32 : buffer std_logic_vector(BW-1 downto 0);
                b_alu32 : buffer std_logic_vector(BW-1 downto 0);
                alu_op : in alu_function_type;--operation code
                g : out std_logic;              --greater
                e : out std_logic;              --equal
                l : out std_logic;              --less
                o_alu32 : buffer std_logic_vector(BW-1 downto 0); --output
                c_alu32 : inout std_logic;      --carry
                ov_alu32 : out std_logic);      --overflow flag
end alu32;
architecture Behavioral of alu32 is
    COMPONENT alu_1bit
        Port (A : in  STD_LOGIC;
            B : in  STD_LOGIC;
                cin: in STD_LOGIC;
            opsel : in  STD_LOGIC_VECTOR (3 DOWNTO 0);
            output : out  STD_LOGIC;
            cout : out  STD_LOGIC);
    END COMPONENT;
    COMPONENT comparator
        PORT (in_0 : IN STD_LOGIC ;
                in_1 : IN STD_LOGIC ;
                greater_in : IN STD_LOGIC;
                equal_in : IN STD_LOGIC;
                less_in : IN STD_LOGIC;
                greater : OUT STD_LOGIC ;
                equal : OUT STD_LOGIC ;
                less : OUT STD_LOGIC);
    END COMPONENT;
    signal carry :std_logic_vector(BW downto 0);
    signal gs, es, ls : std_logic_vector (BW-1 downto 0);
begin
    process(RI, a_alu32, b_alu32, alu_op)
        variable o_alu32var: std_logic_vector(BW-1 downto 0);
    begin
        case alu_op is
            ---None---
            when (alu_op = "0000") =>
                o_alu32 <= "00000000000000000000000000000000";
            ---move/I---
                if (RI='0') then
                    o_alu32 <= a_alu32;
                else
                    o_alu32 <= b_alu32;
                end if;
            ---SLL---
            when (alu_op="1001") =>
                o_alu32 <= to_stdlogicvector(to_bitvector(a_alu32) SLL (to_integer(b_alu32)));
            ---arthmetic and logic---
                carry(0) <= '0';
                z1: FOR i IN 0 to BW-1 loop
                    a1: alu_1bit port map(a_alu32(i), b_alu32(i), carry(i), alu_op, o_alu32var(i), carry(i+1));
                END loop z1;
                c_alu32<=carry(BW);
                ov_alu32 <= (a_alu32(31) and b_alu32(31) and not o_alu32(31)) or (not a_alu32(31) and not b_alu32(31) and o_alu32(31)) when (alu_op = "0001" or alu_op = "0010")
                else '0';
            ---COMP---
                gs(0) <= '0';
               ls(0) <= '0';
            es(0) <= '1';
                g1: for i in 0 to BW-1 loop
                comparator32: comparator port map(a_alu32(i), b_alu32(i), gs(i), es(i), ls(i), gs(i+1), es(i+1), ls(i+1));
            END loop g1;
                g <= gs(BW);
                e <= es(BW);
                l <= ls(BW);
        END CASE;
    END PROCESS;
end Behavioral;
Re: VHDL Error: cannot determine exact overloaded matching definition for "="
You didnt include the code for the c31L_pack package.
But I suspect you didnt create an = function for your custom type.
You don't need to specify alu_op = "xxxx" in your when statement. Only the "xxxx" is needed.
