VHDL code of following structures?
soc
Junior Member level 3
I would like to know the VHDL code for the hardware structure.
Thanks[/img]
Hello Soc,
The VHDL code u have asked for is very easy and i am sure any VHDL programer will hardly take any time to code it .. But if this is turtorial one my advice is please to go through soem VHDL sides .. i am sure u can code urself in no time ,,,
One suggestion i can give is .. The first and second fig in the doc u have provided are interlinked .. u can write VHDL code for the first one and use this as component declaration for structural description of the second one ..
suresh
research235 said:
Hello Soc,
suresh
Yes its easy for someone who know VHDL programming but for someone doing VHDL for the first time, such hardware structure is not easy to code.
It would be good if u can provide the code and then give the explanation how they are interlinked.
Thanks
Solution for 2.10...
library ieee;
use ieee.std_logic_1164.all;
entity FA is
  port (
    a    : in  std_logic;
    b    : in  std_logic;
    cin  : in  std_logic;
    cout : out std_logic;
    sum  : out std_logic);
end FA;
architecture behave of FA is
begin  -- behave
  sum <= a xor b xor cin;
  cout <= (a and b) or (b and cin) or (a and cin);
end behave;
library ieee;
use ieee.std_logic_unsigned.all;
entity serial_add16 is
  port (
    A     : in  std_logic;
    B     : in  std_logic;
    rst_n : in  std_logic;
    clk   : in  std_logic;
end serial_add16;
architecture behave of serial_add16 is
component FA
  port (
    a    : in  std_logic;
    b    : in  std_logic;
    cin  : in  std_logic;
end component;
signal counter : std_logic_vector(3 downto 0);
signal zero : std_logic;
signal Cin, Cin_reg : std_logic;
signal Cout : std_logic;
begin  -- behave
  zero <= not (counter(3) or counter(2) or counter(1) or counter(0));
  with zero select
    Cin <= '0'  when '1',
           Cout when others;
  registers: process (clk, rst_n)
  begin  -- process registers
    if rst_n = '0' then                 -- asynchronous reset (active low)
      counter <= (others => '0');
      Cin_reg <= '0';
    elsif clk'event and clk = '1' then  -- rising clock edge
      counter <= counter + 1;
      Cin_reg <= Cin;
    end if;
  end process registers;
  fa0 : FA port map (
    a    => A,
    b    => B,
    cin  => Cin_reg,
    cout => Cout,
    sum  => sum);
end behave;
    soc
Solutions for 2.14 a, b, c, d
library ieee;
entity counter_a is
  port (
    clk   : in  std_logic;
    q  : out std_logic);
end counter_a;
architecture behave of counter_a is
signal count, count_nx : std_logic_vector(3 downto 0);
begin  -- behave
  q <= not (count(3) or count(2) or  count(1) or count(0));
  count_nx <= count + 1;
  begin  -- process
      count <= (others => '0');
      count <= count_nx;
    end if;
  end process;
end behave;
library ieee;
entity counter_b is
  port (
    clk   : in  std_logic;
    q  : out std_logic);
end counter_b;
architecture behave of counter_b is
begin  -- behave
  q <= not (count_nx(3) or count_nx(2) or  count_nx(1) or count_nx(0));
  begin  -- process
      count <= count_nx;
    end if;
  end process;
end behave;
library ieee;
entity counter_c is
  port (
    clk   : in  std_logic;
    q  : out std_logic);
end counter_c;
architecture behave of counter_c is
signal q_nx : std_logic;
begin  -- behave
  q_nx <= not (count(3) or count(2) or  count(1) or count(0));
  begin  -- process
      q <= '0';
      count <= count_nx;
      q <= q_nx;
    end if;
  end process;
end behave;
library ieee;
entity counter_d is
  port (
    clk   : in  std_logic;
    q  : out std_logic);
end counter_d;
architecture behave of counter_d is
begin  -- behave
  q_nx <= not (count_nx(3) or count_nx(2) or  count_nx(1) or count_nx(0));
  begin  -- process
      q <= '0';
      count <= count_nx;
      q <= q_nx;
    end if;
  end process;
end behave;
Added after 1 hours 3 minutes:
Solution for 2.12...
library ieee;
entity FA is
  port (
    a    : in  std_logic;
    b    : in  std_logic;
    cin  : in  std_logic;
end FA;
begin  -- behave
end behave;
library ieee;
entity serial_mul16 is
  port (
    clk   : in  std_logic;
    a     : in  std_logic_vector(3 downto 0);
    bi    : in  std_logic;
    product : out  std_logic;
    i     : out std_logic_vector(3 downto 0));
end serial_mul16;
architecture structgen of serial_mul16 is
  component FA
    port (
          a    : in  std_logic;
          b    : in  std_logic;
          cin  : in  std_logic;
  end component;
signal a_and_bi : std_logic_vector(3 downto 0);
signal cin_nx, cin : std_logic_vector(3 downto 0);
signal tmp_nx, tmp : std_logic_vector(4 downto 0);
signal count_nx, count : std_logic_vector(3 downto 0);
begin  -- structgen
  i <= count;
  zero <= not (count(3) or count(2) or count(1) or count(0));
  a_and_bi <= a and bi&bi&bi&bi;
  tmp_nx(3) <= '0';
  product <= tmp_nx(0);
  G_1: for I in 3 downto 0 generate
--                             A B cin cout sum
    full_adder : FA port map
          (tmp(I+1), a_and_bi(I), cin(I), cin_nx(I), tmp_nx(I));
  end generate G_1;
counter: process (clk, rst_n)
begin  -- process counter
    count <= count_nx;
  end if;
end process counter;
registers: process (clk)
    if zero = '1' then
      cin <= (others => '0');
      tmp <= (others => '0');
    else
      cin <= cin_nx;
      tmp <= tmp_nx;
    end if;
  end if;
end structgen;
    soc
