VHDL Code Of 2 input XOR -gate
channaveer_018
Newbie level 1
I am new to VHDL programing and i had written a VHDL code on 2 input XOR gate using process and it compiles successfully but in test bench waveform i am unable to get the output that is for all possible inputs i am getting 0 output , I am using Xilinx 9.1 and the following is code
entity XOR2 is
Port ( A : in STD_LOGIC;
B : in STD_LOGIC;
C : out STD_LOGIC);
end XOR2;
architecture Behavioral of XOR2 is
begin
process(A,B)
begin
if((A='0') and (B='1')) then
C<='1';
elsif((A='1') and (B='0')) then
C<='1';
else
C<='0';
end if;
end process;
end Behavioral;
There is no problem with the code ...
Works fine and here is the output in Xilinx ISE 13.1
Your code is fine.
Another way to have the XOR function is
Code VHDL - [expand]
if (A /= B) then C<='1';  -- if A not equal to B
else C<='0';
but in this case you will get a result of 1 even if the inputs are 'U' or 'Z'
or
C<= (A XOR B );
which will give a result of 0/1 only is both inputs are set to 0/1
Alex
i guess the second solution is better because there is no need for process
You can use any of the three ways in or out of a process, you just have to change the if else that can be used only inside the process with when else that can be used out of a process.
C<='1' WHEN (A /= B)
ELSE  '0';
C<='1' WHEN ((A='0') and (B='1')) OR ((A='1') and (B='0'))
ELSE  '0';
Alex
