hitx
Member level 2
Hi dear friends,
Why I always get an error for signal operation (bold part of the codes) for the VHDL codes below .. Thanks now
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity main_REAL is
port (
SW : in std_logic;
result : out std_logic_vector (7 downto 0)
end main_REAL;
architecture Behavioral of main_REAL is
signal int : integer;
begin
process (SW)
variable Xn : real;
variable i : integer;
begin
Xn := 0.25;
i := 1;
while i <= 1 loop
Xn := 4 * Xn * (1-Xn);
i := i + 1;
end loop;
int <= integer (Xn*100);
result <= conv_std_logic_vector (int, 8);
end process;
end Behavioral;
library IEEE;
entity main_REAL is
port (
SW : in std_logic;
end main_REAL;
begin
process (SW)
variable Xn : real;
begin
Xn := 0.25;
i := 1;
while i <= 1 loop
i := i + 1;
end loop;
end process;
end Behavioral;
