thigmotropism
Newbie level 1
Hello all,
I'm hoping someone can give advice on how to properly handle signals between processes.
The gist of the code below is that there are 3 components, P_INIT, P_CONF and P_CMDR, and a FSM that selects how signals are connected between them and the entity's ports. The sequence of the FSM is:
The code may have technical flaws but this is more of a design question. Is using a FSM like this a sensible way to connect processes? Or would I be better off figuring out pure combinational logic? Or maybe something else?
Regards,
thigmotropism
- Start in IDLE and go to INIT when port start='1'.
- While in INIT, start the process in P_INIT and connect its data out to port's data out.
- When P_INIT finishes its task, P_CONF and P_CMDR are started and the FSM goes to CONF.
- In CONF, P_CMDR ready (output) is connected to P_CONF ready (input) and P_CONF data (output) is connected to P_CMDR (input), so that P_CONF can send data to P_CMDR for processing and be notified when P_CMDR is ready for more.
- When P_CONF does all it needs to do, the FSM goes into READY_STATE.
- In READY_STATE, P_CMDR ready is connected to port ready and the FSM waits for port start='1'.
- When it gets start='1', port dataIn is connected to P_CMDR dataIn and the FSM goes to BUSY.
- In state BUSY, P_CMDR is processing the input and its dataOut is connected to port's dataOUT.
- When finished, FSM returns to READY_STATE to wait for more data.
Regards,
thigmotropism
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 entity SampleEntity is port(clk, reset : in std_logic; start, dataIn : in std_logic; ready, dataOut: out std_logic;); end SampleEntity; architecture Arch of SampleEntity is type State is (IDLE, INIT, CONF, READY_STATE, BUSY); signal currentState_reg, currentState_next: State; signal INIT_start, INIT_done, INIT_data: std_logic; signal CONF_start, CONF_ready, CONF_done, CONF_data: std_logic; signal CMDR_start, CMDR_ready, CMDR_dataI, CMDR_dataO: std_logic; begin P_INIT: entity work.Predefined_INIT(Arch) port map (--ins clk => clk, reset => reset, start => INIT_start, --outs done => INIT_done, data => INIT_data); P_CONF: entity work.Predefined_CONF(Arch) port map (--ins clk => clk, reset => reset, start => CONF_start, ready => CONF_ready, --outs done => CONF_done, data => CONF_data); P_CMDR: entity work.Predefined_CMDR(Arch) port map (--ins clk => clk, reset => reset, start => CMDR_start, dataI => CMDR_dataI, --outs ready => CMDR_ready, dataO => CMDR_dataO); -- Sync state transitions with clk Synchro: process(clk, reset) begin if reset='1' then currentState_reg <= IDLE; elsif rising_edge(clk) then currentState_reg <= currentState_next; end if; end process Synchro; -- Next-state logic NextState: process(start, dataIn, currentState_reg, INIT_done, INIT_data, CONF_done, CONF_start, CONF_data, CMDR_ready , CMDR_dataO) begin -- Default values currentState_next <= currentState_reg; -- Interprocess signals INIT_start <= '0'; CONF_start <= '0'; CONF_ready <= '0'; CMDR_start <= '0'; CMDR_dataI <= '0'; -- port outs ready <= '0'; dataOut <= '0'; case currentState_reg is when IDLE => -- Stay IDLE until user sends enable. if start='1' then currentState_next <= INIT; end if; when INIT => -- Send start signal to P_INIT. INIT_start <= '1'; -- Send P_INIT data to port dataOut dataOut <= INIT_data; -- Stay INIT until P_INIT says done. if INIT_done='1' then -- Send start signal to P_CONF and P_CMDR CONF_start <= '1'; CMDR_start <= '1'; currentState_next <= CONF; end if; when CONF => -- Send P_CMDR ready to P_CONF CONF_ready <= CMDR_ready; -- Send P_CONF data to P_CMDR CMDR_start <= CONF_start; CMDR_dataI <= CONF_data; -- Stay CONF until P_CONF says done. if CONF_done='1' then currentState_next <= READY_STATE; end if; when READY_STATE => -- Send P_CMDR ready to port ready ready <= CMDR_ready; -- Stay in READY_STATE until port starts new dataIn. if start='1' then -- Send port start & dataIn to P_CMDR CMDR_start <= start; CMDR_dataI <= dataIN; currentState_next <= BUSY; end if; when BUSY => -- Send P_CMDR dataO to port dataOut dataOut <= CMDR_dataO -- Stay in BUSY_STATE until P_CMDR says ready. if CMDR_ready='1' then currentState_next <= READY_STATE; end if; end case; end process NextState; end architecture Arch;
