simbaliya
Member level 4
The context is as follow:
My PCB thickness is very thin, and my PCB supplier gives me calculation of a microstrip impedance line for 50ohm, which resilts in a trace width of 75um, trace length about 20mm.
The trace is connecting output of RFIC PA to BAW filter, the application will use Bluetooth Low Energy.
My question is, assume the supplier calculation is correct that I get 50ohm for this line, RFIC PA output and BAW input are design with 50ohm, will this very thin 75um trace be a problem to handle the power transmitted by Bluetooth @ Low Energy for worst case scenario?
