very low noise Bandgap reference
jt_rf
Member level 2
Member level 2
low noise bandgap
Is it possible to design a very low noise bandgap reference?
(without using any RC filter).
Will it help using a chopper?
say 20-30uV rms in 10hz to 100kHz.
thanks in advance.
JT
usually chopping requires a filter to remove the ripples
band-gap reference filtering
jt_rf said:
... say 20-30uV rms in 10hz to 100kHz. JT
Even the dedicated analog semi companies hardly can achieve this :cry:
S. e.g. **broken link removed**.
low noise band gap reference
Thaks eriki,
i have gone thru this datasheet.
but the current consumption is very high....prohibitively high...
regards,
JT
