upasana sahu
Newbie
Hello,
I am trying to write verilog-A code to model a circuit that acts as an analog timer.
By default, the output is low .Then calculate time (t) and the output should be high for a constant time (t+delt) then it goes low again and repeat it
Any help?
Any help?
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 module Neuron16Jan(IN1,IN2,R1,G1); input IN1,IN2; output R1; output G1; electrical IN1,IN2,G1; electrical gnd; //internal port electrical R1; parameter real slope_velocity_vs_currentdensity=0.11; parameter real vlogic_low=225e-3; parameter real vlogic_high=703e-3; parameter real total_distance=5800e-9; parameter real delt=209n; real t; real t1; integer temp,next; analog begin V(gnd)<+0; t=(total_distance)/((slope_velocity_vs_currentdensity)*(I(IN1,gnd)+I(IN2,gnd))*1e6); t1=((total_distance)/((slope_velocity_vs_currentdensity)*(I(IN1,gnd)+I(IN2,gnd))*1e6))+209n; @(initial_step) begin temp=0; end @(timer(t)) begin temp=0; end @(timer(t,t1)) begin temp=1; end V(R1)<+ transition(temp ? vlogic_high:vlogic_low,0.01n,0.01n); end endmodule
