verilog signed operation in modelsim
3wais
Member level 4
Member level 4
Alexandria,Egypt
I have written a verilog file that implements some arithmetic operations, I defined my signals as
wire signed
or
reg signed
. when I simulate that on isim simulator it does the operation as specified, with signed arithmetic. but when I simulate the same file in modelsim it behaves as if the signals are unsigned!
I have to use modelsim because I need to load some memory files (Isim does not load memory files, you have to load the memory by hand!) so I need to get this fixed. how to make modelsim interpret the signals as signed? in operation not in wave viewer of course?
With which operations do you see incorrect behaviour? There aren't so many where the difference matters at all. (e.g. multiply, sign extension, compare).
