boblettoj99
Newbie level 2
- Joined
- Feb 24, 2010
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Bristol, UK
- Activity points
- 1,299
Hi, i have a weird problem with my coursework, basically we have to write an 8 bit adder using only logic gates. This is my first time using verilog and i'm sure you'll agree its very confusing coming from C programming to this!
Anyway, these two modules are what i have come up with, the 1bit adder works perfectly however when i test the 8bit one it doesn't work properly, as far as i can tell the carry-in is not being assigned properly and stays at 0 throughout the whole calculation. Can anyone tell me why this is?
Thanks, Ed.
Thanks, Ed.
module add_8bit ( output wire co,
output wire [7:0] r,
input wire ci,
input wire [7:0] x,
input wire [7:0] y );
add_1bit t0 ( r[0], ci, x[0], y[0], ci ) ;
add_1bit t1 ( r[1], ci, x[1], y[1], ci ) ;
add_1bit t2 ( r[2], ci, x[2], y[2], ci ) ;
add_1bit t3 ( r[3], ci, x[3], y[3], ci ) ;
add_1bit t4 ( r[4], ci, x[4], y[4], ci ) ;
add_1bit t5 ( r[5], ci, x[5], y[5], ci ) ;
add_1bit t6 ( r[6], ci, x[6], y[6], ci ) ;
add_1bit t7 ( r[7], co, x[7], y[7], ci ) ;
endmodule
//adds 2 bits together
module add_1bit ( output wire r,
output wire co,
input wire x,
input wire y,
input wire ci );
//wires to carry results of operations
wire w0, w1, w2 ;
//XOR x and y and put on wire w0
xor t0 ( w0, x, y ) ;
//AND x and y and put on wire w1
and t1 ( w1, x, y ) ;
//XOR w0 and ci to get result
xor t2 ( r, w0, ci ) ;
//AND w0 and ci
and t3 ( w2, w0, ci ) ;
//OR w1 and w2 to get carry out
or t4 ( co, w1, w2 ) ;
endmodule
