Saptarshi1992
Newbie level 1
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 module approximateMultiplier( input [7:0] a,b, output [15:0] s ); wire [15:0] p0, p1, p2, p3 ,p4 ,p5, p6, p7; wire [15:0] q0, q1, q2, q3; wire [15:0] r0, r1; wire [15:0] e1, e2, e3, e4, e5, e6, e7; wire [15:0] s_, e_, E; wire [4:0]c; supply0 zero; //generating the partial products p0-p7 assign p0 = b[0]*a; assign p1 = b[1]*a; assign p1 = p1<<1; assign p2 = b[2]*a; assign p2 = p2<<2; assign p3 = b[3]*a; assign p3 = p3<<3; assign p4 = b[4]*a; assign p4 = p4<<4; assign p5 = b[5]*a; assign p5 = p5<<5; assign p6 = b[6]*a; assign p6 = p6<<6; assign p7 = b[7]*a; assign p7 = p7<<7; integer i; //loop variable //Zero pad the remaining bits int the left side of p0-p7 assign p0[15:8] = 8'b0000_0000; assign p1[15:9] = 7'b0000_000; assign p2[15:10] = 6'b0000_00; assign p3[15:11] = 5'b0000_0; assign p4[15:12] = 4'b0000; assign p5[15:13] = 3'b000; assign p6[15:14] = 2'b00; assign p7[15] = 1'b0; //Now we have p0-p7. Genarate q0-q3 for(i=0; i<=8; i=i+1) //ERROR IN THIS LINE begin if(i==0) //the 0-th bit will not have any (i-1)-th term. Hence, seperately calculated. begin //assigning the values to the 0-th bits of q0-q3 assign q0[i] = p0[i]^p1[i]; assign e1[0] = 0; assign q1[i] = 0; assign q1[i+1] = 0; assign q1[i+2] = p2[i+2]^p3[i+2]; assign e2[i] = 0; assign e2[i+1] = 0; assign q2[i] = 0; assign q2[i+1] = 0; assign q2[i+2] = 0; assign q2[i+3] = 0; assign q2[i+4] = p4[i+4]^p5[i+4]; assign e3[i] = 0; assign e3[i+1] = 0; assign e3[i+2] = 0; assign e3[i+3] = 0; assign q3[i] = 0; assign q3[i+1] = 0; assign q3[i+2] = 0; assign q3[i+3] = 0; assign q3[i+4] = 0; assign q3[i+5] = 0; assign q3[i+6] = p6[i+6]^p7[i+6]; assign e4[0] = 0; assign e4[i+1] = 0; assign e4[i+2] = 0; assign e4[i+3] = 0; assign e4[i+4] = 0; assign e4[i+5] = 0; //assigning the values to the 0-th bits of r0 and r1 assign r0[i] = q0[i]^q1[i]; assign e5[0] = 0; assign r1[i] = 0; assign r1[i+1] = 0; assign r1[i+2] = 0; assign r1[i+3] = 0; assign r1[i+4] = q2[i+4]^q3[i+4]; assign e6[i] = 0; assign e6[i+1] = 0; assign e6[i+2] = 0; assign e6[i+3] = 0; //assigning the values to the 0-th bits of s_ assign s_[i] = r0[i]^r1[i]; assign e7[0] = 0; end else //fill other bits begin assign q0[i] = (p0[i]^p1[i]) | (p0[i-1] & p1[i-1]); assign e1[i] = (p0[i]^p1[i]) & p0[i-1] & p1[i-1]; assign q1[i+2] = (p2[i+2]^p3[i+2]) | (p2[i+1] & p3[i+1]); assign e2[i+2] = (p2[i+2]^p3[i+2]) & p2[i+1] & p3[i+1]; assign q2[i+4] = (p4[i+4]^p5[i+4]) | (p4[i+3] & p1[i+3]); assign e3[i+4] = (p4[i+4]^p5[i+4]) & p4[i+3] & p1[i+3]; assign q3[i+6] = (p6[i+6]^p1[i+6]) | (p0[i+5] & p1[i+5]); assign e4[i+6] = (p6[i+6]^p1[i+6]) & (p0[i+5] & p1[i+5]); end end //Zero pad the remaining bits int the left side of q0-q3 for(i=9; i<=15; i=i+1) begin assign q0[i] = 0; assign q1[i+2] = 0; assign q2[i+4] = 0; assign q3[i+6] = 0; end //Now we have q0-q3. Generate r0 and r1 for(i=1; i<=10; i=i+1) begin assign r0[i] = (q0[i]^q1[i]) | (q0[i-1] & q1[i-1]); assign e5[i] = (q0[i]^q1[i]) & q0[i-1] & q1[i-1]; assign r1[i+4] = (q2[i]^q3[i]) | (q2[i-1] & q3[i-1]); assign e6[i+4] = (q2[i]^q3[i]) & q2[i-1] & q3[i-1]; end //Zero pad the remaining bits int the left side of r0 and r1 for(i=11; i<=15; i=i+1) begin assign r0[i] = 0; assign r1[i+4] = 0; end //Now we have r0 and r1. Genarate s_ for(i=1; i<=15; i=i+1) begin assign s_[i] = (r0[i]^r1[i]) | (r0[i-1] & r1[i-1]); assign e7[i] = (r0[i]^r1[i]) & r[i-1] & r1[i-1]; end //Now we have s_. Accumlate e_ = e3|e4|e6|e7 assign e_ = e3|e4|e6|e7; //mask all other bits of e_ and keep 11-14 alive only. Save this error part in E assign mask = 16'h7800; assign E = mask & e_; //we have s_ and accumulated error E. Add them to get the inaccurate result. assign s = s_; fullAdder F1(s_[11], E[11], zero, s[11], c[0]); fullAdder F2(s_[12], E[12], c[0], s[12], c[1]); fullAdder F3(s_[13], E[13], c[1], s[13], c[2]); fullAdder F4(s_[14], E[14], c[2], s[14], c[3]); fullAdder F5(s_[15], c[3], zero, s[15], c[4]); endmodule
ERROR:HDLCompilers:26 - "approximateMultiplier.v" line 72 expecting 'endmodule', found 'for'
Not only in the loop which i have marked as error, but also, in the other for loop used, i am getting this error. Can anyone plz help me solve the problem?
Thanking in Advance
