verilog a code for ideal ADC
tibusso
ireland
Hi all,
I try to compile this code but there is an error in line 42:
localparam integer levels = 1<<`bits;
Can someone help me to solve the error? following there is the entire code.
* N-bit Analog / Digital Converters
* Input range is from vmin to vmax.
* Version 1c, 10 February 2008
* Ken Kundert
* Downloaded from The Designer's Guide Community (www.designers-guide.org).
* Post any questions on www.designers-guide.org/Forum.
* This ADC is preferred over the version given in Listing 26 of Chapter 3
* of "The Designer's Guide to Verilog-AMS" by Kundert & Zinke.
* These versions were modified to work around limitations in the
* existing version of Spectre (6.1.1 May 2007). As such, they
* are less capable than the originals and should discarded
* once Spectre is fixed (though it has been 12 years ...).
`define bits 8
`include "disciplines.vams"
// N-bit Analog to Digital Converter
module adc (out, in, clk);
// parameter integer bits = 8 from [1:24]; // resolution (bits)
parameter real vmin = 0.0; // minimum input voltage (V)
parameter real vmax = 1.0 from (vmin:inf); // maximum input voltage (V)
parameter real td = 0 from [0:inf); // delay from clock edge to output (s)
parameter real tt = 0 from [0:inf); // transition time of output (s)
parameter real vdd = 5; // voltage level of logic 1 (V)
parameter real vss = 0; // voltage level of logic 0 (V)
parameter real thresh = (vdd+vss)/2; // logic threshold level (V)
parameter integer dir = +1 from [-1:1] exclude 0;
// 1 for trigger on rising edge
// -1 for falling
input in, clk;
output [`bits-1:0] out;
voltage in, clk;
voltage [`bits-1:0] out;
integer result;
genvar i;
analog begin
@(cross(V(clk)-thresh, dir) or initial_step) begin
result = levels*((V(in) - vmin))/(vmax - vmin);
if (result > levels-1)
result = levels-1;
else if (result < 0)
result = 0;
end
for (i=0; i<`bits; i=i+1)
V(out) <+ transition(result & (1<<i) ? vdd : vss, td, tt);
end
endmodule
Thank you
What kind error do you have?
Could you also share the content of disciplines.vams file?
Bests,
Tiksan
Thanks Syswip for reply!
Spectre finds an error during SpectreHDL compile. There is a syntax error in this line: "localparam integer levels = 1<<`bits;"
Sorry but I'm not an expert with verilog. Where can I find disciplines.vams file?
Added after 5 hours 11 minutes:
Ok. I solved the problem by using the Cadence ModelWriter component. I attach an interesting tutorial about this topic.
