[SOLVED] Verifying the CRC-16-CCITT calc
dpaul
Germany
I have implemented the CRC-16-CCITT (x^16 + x^12 + x^5 + 1) with Normal Polynomial 0x1021 and Initial value = x"FFFF".
I have implemented the VHDL function in a package file as shown below.
   -- CRC16 function
   function f_crc16_ccitt_d8 (
      data_in : std_logic_vector(7 downto 0);  -- Input byte data
      crc_in  : std_logic_vector(15 downto 0)) -- Input 16 bit CRC from initial/prev stage
      return std_logic_vector is                       -- Return the final 16 bit CRC
      variable d:      std_logic_vector(7 downto 0);
      variable c:      std_logic_vector(15 downto 0);
      variable newcrc: std_logic_vector(15 downto 0);
   begin
      d := data_in;
      c := crc_in;
      newcrc(0) := d(4) xor d(0) xor c(8) xor c(12);
      newcrc(1) := d(5) xor d(1) xor c(9) xor c(13);
      newcrc(2) := d(6) xor d(2) xor c(10) xor c(14);
      newcrc(3) := d(7) xor d(3) xor c(11) xor c(15);
      newcrc(4) := d(4) xor c(12);
      newcrc(5) := d(5) xor d(4) xor d(0) xor c(8) xor c(12) xor c(13);
      newcrc(6) := d(6) xor d(5) xor d(1) xor c(9) xor c(13) xor c(14);
      newcrc(7) := d(7) xor d(6) xor d(2) xor c(10) xor c(14) xor c(15);
      newcrc(8) := d(7) xor d(3) xor c(0) xor c(11) xor c(15);
      newcrc(9) := d(4) xor c(1) xor c(12);
      newcrc(10) := d(5) xor c(2) xor c(13);
      newcrc(11) := d(6) xor c(3) xor c(14);
      newcrc(12) := d(7) xor d(4) xor d(0) xor c(4) xor c(8) xor c(12) xor c(15);
      newcrc(13) := d(5) xor d(1) xor c(5) xor c(9) xor c(13);
      newcrc(14) := d(6) xor d(2) xor c(6) xor c(10) xor c(14);
      newcrc(15) := d(7) xor d(3) xor c(7) xor c(11) xor c(15);
   return newcrc;
 end function f_crc16_ccitt_d8;
The function takes a byte and the initial/previous CRC value (if the input byte is the 1st byte then crc input = 0xFFFF) as inputs and returns the 16 bit calculated CRC value.
I am calculating the CRC for a 11 byte data, i.e. a loop running 11 times calls this function and calculates the final CRC.
Now the above is done in hardware, at the FPGA. The frame data (11 bytes data + 16 bits CRC) is received from the processor where a firmware calculates the CRC and sends it along with trhe data. My design at the FPGA re-calc the CRC from the data received. My calc CRC and the one received should match.
Current situation is that they are not matching!
I want to know how can I verify this calc for CRC-16-CCITT, without doing the calc manually by hand? What are my options?
use online CRC calculators
Just do an internet search.
You are also free to use readily available code.
