hmsheng
Full Member level 4
VCO noise
A 3GHz VCO was designed with on-chip inductor model. Two kinds of models were used, s-parameter model and spice-model that was extracted from the s-paramtere model. When I simulate the VCO phase noise with the two kinds of models there is much differenct. The phase nosie is better if I use the spice inductor model. The phase noise will worse 3dB or more if the s-paramter model is used. In the noise contribution, NPORT0 which is the inductor s-paramter component contribute 82% noise. That's abnormal!
I doubt we can't use s-parameter file to simulate VCO phase noise. Is that?
