GeoAVR
Member level 2
- Joined
- Jun 4, 2014
- Messages
- 48
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 366
Hi all,
I want to build a data acquisition system for 0-10MHz signals but I am having trouble with the variable gain required before the ADC.
I am using a High speed differential output opamp to drive the ADC but since the input signal has variable Vpp voltage I would like to implement a variable gain amplifier.
Is a digital potentiometer enough to select gains: 0.1 , 1, and 10 through the resistor network that sets the gain of the Opamp or is there a different approach for high speed signal acquisition?
Additionally, since my source has a 50 Ohm resistance, changing the resistors might change the input resistance of the system. How do I solve this?
Thank you in advance.
