nathan80
Member level 3
i m currently doing the layout for a pcie add in card using a 4 layer board.
the high speed differential Rx and Tx (propagating till 2.5GHz signals) are not placed in the same layer at the golden finger connector.
please check the layout below:
top layer - red traces
bottom layer - blue traces
the Rx diff traces are connected to the golden finger connector on the top layer.
the tx diff traces has to go through a caps and conncted to the golden finger connector at the bottom layer.
please tell me, if this layout topology can be used: i could not find any guideline on routing high speed differential traces using via
