Using generate in another generate
masoud.malekzadeh
Member level 1
HI , is it possible to use a generate statement inside another generate statement ?
here is my code but my pre1 and pre2 types are undefined .
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
gen15:for j in 1 to 7 generate
gen12:for i in 0 to 7 generate
s74:multiplier port map (a =>z1(i),b=>ww1(j-1),clk => clk,result =>pre1(i));   -------
s75:multiplier port map (a =>z2(i),b=>ww2(j-1),clk => clk,result =>pre2(i));   -------
s76:adder port map (a =>pre1(i),b=>pre2(i),clk => clk,result =>pre3(i));
s77:multiplier port map (a =>pre3(i),b=>pre3(i),clk => clk,result =>pre4(i));
s78:multiplier port map (a =>pre3(i),b=>pre4(i),clk => clk,result =>pre5(i));
s79:multiplier port map (a =>z1(i),b=>pre5(i),clk => clk,result =>pre6(i));
s82:multiplier port map (a =>ww1(j-1),b=>three,clk => clk,result =>nww1(j-1));
end generate ;
gen13:for i in 0 to 3 generate
s80:adder port map (a =>pre6(2*i),b=>pre6((2*i)+1),clk => clk,result =>pre7(i));
end generate ;
gen14:for i in 0 to 1 generate
s81:adder port map (a =>pre7(2*i),b=>pre7((2*i)+1),clk => clk,result =>pre8(i));
end generate ;
s83:adder port map (a =>pre8(0),b=>pre8(1),clk => clk,result =>pre9(j));
s84:subtractor port map (a =>pre9(j),b=>nww1(j-1),clk => clk,result =>ww1(j));
end generate;
Yes.
here is my code but my pre1 and pre2 types are undefined.
Without the full code, it is not really possible to spot the error, but I do note that you don't have an 'end generate' for the outermost generate statement.
Kevin Jennings
I feel generate inside generate will increase more confusion and make the code look untidy....
I want to design a processor that one part of which should be like this
W(k)=Pre_W(k)-3*W(k-1)
pre_W(k)=∑x1(i)[x1(i)*W(k-1)+x2(i)*W(k-1)]^3 i=0 to 7
and my arithmetic operations is floating point i should port map them using components .
thanks .
Then what should i do in order to repeat the generate for several times ,?
if after finishing the generate one signal changes the generate will run again ? for example the generate belows finishes for the first time if i update D(i) , the generate will start again ?
for .... generate
x(i)<=D(i)
end generate .
s74:multiplier port map (a =>z1(i),b=>w1(0),clk => clk,result =>pre1(i));
s75:multiplier port map (a =>z2(i),b=>w2(0),clk => clk,result =>pre2(i));
s76:     adder port map (a =>pre1(i),b=>pre2(i),clk => clk,result =>pre3(i));
s82:multiplier port map (a =>w1(0),b=>three,clk => clk,result =>nw1(0));
end generate ;
end generate ;
end generate ;
s83:adder port map (a =>pre8(0),b=>pre8(1),clk => clk,result =>pre9(0));
s84:subtractor port map (a =>pre9(0),b=>nw1(0),clk => clk,result =>w1(1));
In this code i implemented the algorithm that computes only W(1) and the result is ok but to go further W(2),W(3),..... I'm confused ....
Add a generate statement on top of this with 3 index values. What is the problem in doing so?...
by doing that my code is like this
for j in  0 to 7 generate
s74:multiplier port map (a =>z1(i),b=>w1(j),clk => clk,result =>pre1(i));
s75:multiplier port map (a =>z2(i),b=>w2(j),clk => clk,result =>pre2(i));
s82:multiplier port map (a =>w1(j),b=>three,clk => clk,result =>nw1(j));
end generate ;
end generate ;
end generate ;
s84:subtractor port map (a =>pre9(j),b=>nw1(j),clk => clk,result =>w1(j+1));
end generate ;
end generate ;
Doing so my pre1 and pre2,pre3,pre4 go undefined .
