teja321
Member level 1
Using CE of SRL
The input to the Board is 16 Mhz. Hence using SRL i have divided the clock to a frequency of 1 Hz and i am using this clock to drive LED's in a sequence.
Now the issue is that i am using the divided o/p of one SRL as a clock input to another SRL which infers multiple generated clock during synthesis.
To avoid this i want to use the o/p of SRL as Clock enable (CE) to the next SRL. I tried connecting the o/p of each SRL to CE but it doesn't divide the 16 Mhz to 1 Mhz.
So any ideas how can i do so??
module led_counter(clk,led_out, rst);
input clk, rst;
output reg [3:0] led_out;
wire clk_buf;
assign one = 1'b1;
assign zero = 1'b0;
wire [6:0] clk_en;
////////////BUFG INSTANTIATION/////////////////////
BUFG BUFG_1 (
.O(clk_buf), // Clock buffer output
.I(clk) // Clock buffer input
// Input clock of 16 Mhz
// Divide by 16
SRLC16E #(.INIT(16'h0001)) // Initial Value of Shift Register
SRLC16E_1 (
.Q(), // SRL data output
.Q15(clk_en[0]), // Carry output (connect to next SRL)
.A0(one), // Select[0] input
.A1(one), // Select[1] input
.A2(one), // Select[2] input
.A3(one), // Select[3] input
.CE(one), // Clock enable input
.CLK(clk_buf), // Clock input
.D(clk_en[0]) // SRL data input
genvar i;
generate
for (i=0; i < 6; i=i+1)
begin: gen_10_srl
// Divide by 16 x 10^6 = 16 Mhz/16_000_000 = 1Hz
SRLC16E_2 (
.Q(clk_en[i+1]), // SRL data output
.Q15(), // Carry output (connect to next SRL)
.A1(zero), // Select[1] input
.A2(zero), // Select[2] input
.CLK(clk_en[i]), // Clock input
.D(clk_en[i+1]) // SRL data input
end
endgenerate
reg clk_1s_d;
always @(posedge clk_buf)
clk_1s_d <= clk_en[6];
assign clk_1s = clk_en[6] & (~clk_1s_d);
always @(posedge clk_buf or posedge rst) begin
if(rst == 1'b1)
led_out <= 4'b1110;
else if (clk_1s == 1'b1) begin
case (led_out)
4'b0111 : led_out <= 4'b1110;
4'b1110 : led_out <= 4'b1101;
4'b1101 : led_out <= 4'b1011;
4'b1011 : led_out <= 4'b0111;
endcase
end
end
endmodule
