general_pete
Hi there,
I'm trying to make a prototype system for low bitrate transmission at 5.8 GHz using existing transceiver ICs, the problem being that many of those available (e.g. RFMD’s ML5800/ML5805, Atmel’s ATR2820, PHYCHIP’s PD5000) are either obsolete or soon to be obsolete.
I've found one from Maxim, the MAX2828 802.11a/b/g WLAN transceiver IC, it's typically used with a OFDM/DSSS baseband processor to encode the analog baseband I/Q signals for transmission and demodulate the received analog baseband I/Q signals. I was wondering if you think it is possible to just use a simple BPSK modulation scheme instead to provide the I/Q signals?
I was thinking that I could set the Q signal to 0, then use a digital bit stream input to a Schmitt trigger to give a NRZ signal which could be low-pass filtered to give the I signal for transmission. If I use a similar setup at the receive I/Q output, i.e. a low-pass filter, and theshold detector to reconstruct the original bit stream will I be able to demodulate the data ok do you think?
Any help would be much appreciated, thanks!
