AbhinavRajan
Junior Member level 1
I have a few basic doubts regarding this USB to UART bridge IC - XR21B1424 - https://www.maxlinear.com/ds/xr21b1424.pdf
My questions are just from the hardware perspective.
1. This IC converts USB protocol to UART protocol at the available 4 output channels, right? Is there any software within the IC that will do this conversion of protocol or do we have to write separately - connected to the Host USB side? Like, what should a hardware person keep in mind while using the IC - Like, just connect differential lines on Input and take 4 Tx,Rx lines on the output connected appropriately to the Micro or SOC or whatever IC?
2. If I have one USB 2.0 running at 480Mb/s connected as the input, how is speed and addressing done for each channel? Will all output UART channels operate at the same speed? What happens if two output channels require value from USB at the same time?
