USB to RS-232 adapter schematics?
VSWR
Advanced Member level 3
Anyone having schematics of an USB to RS-232 adapter? I need it for my laptop.
Try this site:
hxtp://www.ftdichip.com/FTSchema.htm
hxtp://www.beyondlogic.org/porttalk/porttalk.htm
hxtp://sourceforge.net/projects/ezusb2131
hxtp://www.indiacam.net/pinout/usbfaq.html
hxtp://www.lvr.com/usb.htm
Maybe this helps
    V
Try this - it works well.
    V
Microchip as also a chip with USB and UART
build in
Hello everybody.
I just want to say .Don't loose
your time with just another USB
chip .I had the opportunity
of using the FTDI chip.
IT is a little wonder..
you can interface it with anything
and the soft is free .
LINUX and MICROCRAP(SOFT) drivers free!!
Has anyone tried the ftdi 245 (USB to FIFO) device? Is it true you can use the same software drivers as for the 232 (USB to serial) part?
Hi GaAs,
try the AT76C711 from ATMEL
go on http://www.atmel.com and USB products
A good dev board is avaible.
By.
Does exist any solution which do not need to instal any SW into PC?
Only any "black box" with cable
pool_77
How about PL-2303? Does anyone use this chip before? Try **broken link removed**. As I know, there is no this kind of class driver in USB spec., thus the driver installed is necessary.
USB and PIC:
Maxim has also a one chip resulution
I heard that on Mac those USB-RS232 converters encounter some problems. Anybody has experienced that too?
