USB PIC Programmer Schematic Needed
faisal_m786
Newbie level 5
Newbie level 5
I need a schematic (with its software) for a tested USB PIC programmer. I do have serial controlled programmers but they dont work with my laptop :cry: I request you to reply ASAP
Thanks :idea:
wp100
Advanced Member level 6
Prime Meridian
Just search this forum for several different designs - the attached Pickit2 Lite being one of the best and easiest to build. ( you do not need the ferrite bead )
All the software is free to download from Microchip, you will need to program the pic18f2550 from your existing programmer.
Note that a few Laptop USB powered programmers can give problems because the laptops usb port cannot deliver adequate power, a powered usb hub usually cures that problem.
anandpv2009
Advanced Member level 1
You can also try GTP USB programmer
barrybear
Full Member level 4
Full Member level 4
A cheap option is to buy a usb to serial port converter .These are vey cheap now and the latest ones do not need a driver installed. Plug and play
sajal1975
Full Member level 2
Full Member level 2
USB CIRCUITS ARE AVALABLE AT ATMEL SITES
