Prakash Rajolli
Newbie level 6
I've never done a USB Host interface before, now I am trying to
enumerate USB Host using NXP's USBHostLite example using LPC1768
controller.
It stuck at "while (!HOST_RhscIntr);"
I got a short serial output followed by flashing
Initializing Host Stack
Host Initialized
Connect a Mass Storage device
Can anybody tell me why
"LPC_USB->OTGStCtrl = 0x3;" statement is using. And if I use
"LPC_USB->OTGStCtrl = 0x203;" this statement then serial output is
followed as
Host Initialized
ERROR: In Host_EnumDev at Line 358 - rc = -1
The line (Line 358 in usbhost_lpc17xx.c) is this block of code:
rc = HOST_GET_DESCRIPTOR(USB_DESCRIPTOR_TYPE_DEVICE, 0, TDBuffer, 8);
if (rc != OK) {
PRINT_Err(rc);
return (rc);
Could it be an issue with my USB drive or hardware?
The schematic for usb host I have attached.
I have ensured that PORT_FUNC in OTGStCtrl register is 0x3, PWRD, PPWR, POVRCR, USB-D+ and USB-D- are set correctly for USB host in PINSELx.
Further observations are as follow,
1. It stuck at "while (!HOST_RhscIntr) ;" and If I not initialize UART, then get rc = -1 at
rc = HOST_GET_DESCRIPTOR (USB_DESCRIPTOR_ TYPE_DEVICE, 0, TDBuffer, 8);
if (rc != OK) {
PRINT_Err(rc) ;
return (rc);
because HOST_TDControlStatu s = 5.
2. Before setting of global power bit in OHCI RHStatus,
HcRhStatus = OR_RH_STATUS_ LPSC; /* Set Global Power */
voltage at PWRD pin is 4.68v and after setting of global power
PWRD = 0.8V
is it correct?
Many thanks in advance,
-Prakash
9886545216
controller.
Host Initialized
followed as
Host Initialized
if (rc != OK) {
PRINT_Err(rc);
return (rc);
if (rc != OK) {
PRINT_Err(rc) ;
return (rc);
PWRD = 0.8V
is it correct?
-Prakash
9886545216
