Usage of the same timer for 2 modules
alexsoad
Newbie level 6
Hello,
My dspic (dsPIC30F3014) does have only 3 timers.
For OC module ( output compare ) and IC module ( input capture ) there are available only 2 timers, Timer 2 and Timer 3.
I need to command 2 DC motors, and i use 2 OC modules, using a timer each.
Now, for my IC module, i do not have any timer left available. I need some help with this issue.
Thank you,
Alex.
Yes, obviously. You can either go for software PWM generation or software event capture, depending on your required timing accuracy. Or use a processor with more independant working timers, e.g. a dsPIC33 motor controller.
"bit 7 ICTMR: Input Capture Timer Select bits
1 = TMR2 contents are captured on capture event
0 = TMR3 contents are captured on capture event
Note: Timer selections may vary. Refer to the device data sheet for details. "
What should i do with this if i use a software timer?
It looks like IC module must have a hardware timer configurated in ICxCON: Input Capture x Control Register
