sbhalerao
Member level 1
Hi to all,
I am a part of a research group that is presently investigating the feasibility of powering sensor nodes.. Our work involves the design of an antenna and a rectifier circuit. The rectifier uses a Zero-biased Schottky diode (Agilent HSMS-2850)..
I am using IE3D for the antenna simulation (for the first time). I am going to connect the antenna directly to the rectifying circuit (without using any matching circuit).. this is to done to avoid bulky components. I have NOT been able to achieve impedance match till now..
The concept is that the impedance of the rectifier circuit should be equal to the impedance of the antenna..
1) ZL and Zc are given ... ZL corresponds to load and Zc is the characteristic impedance of the transmission line... Is load the antenna in my case and the Zc is the impedance of the rectifier circuit???
2) I have to specify ZL.. If it is the antenna impedance, how can I specify it ??? it should come up as Z11??
I understand the concepts, but the terms used in IE3D are not that clear to me... I would be glad if someone could enlighten me on this... The antenna that I am designing is a folded-patch antenna... I know all stuff about that - but this impedance matching business is driving me crazy!!!
