Faizan shafi
Newbie level 5
Hi
I am designing a LNA and for that I am simulating few topologies and seeing the nf , gain of my circuits. as you can see the schematic and graphs, you can tell my noise figure would be large because of no input output matching.
My supervisor told me to play with the values of Zs so that you get less noise figure. He told me specifically not to build a matching network but to just change or sweep the values of Zs and get a noise figure which is smaller than what it is now.
I don't want to sweep the values of Zs. Instead I just want to clear few concepts.
I have plotted Sopt and Zopt on the graph.
At 61Ghz If i look at the values of Zopt, they are 55+41j .
So now If i just change my Zs to 55+41j would it be considered as input matching for minimum noise figure?
Similarly if i look at Zin and lets say it is 12+14j.
And now i change my Zs to 12-14j . Would it be considered as input matching for maximum noise..
AM i correct?
Also can someone explain to me how can I use S11, Sopt for matching my circuits? I am little confused about it. Thank you
AM i correct?
