I have a problem:
when I simulate my cavity in eigenmode, the inner conductor and the shield are silver-plated, and the cavity is filled with air. Do I need to handly set each surface of the shield as silver boundary? If so,is there any convenient way to do it?
I have a problem:
I am not sure whether I completely understand your meaning. IF you already defined the material (silver) for the inner and outer conductor of your cavity, why you need to set the surface? The surface is perfect E by default in HFSS, right?
