you fail to initialize the 'reg' array or its variable's
module PC(din, dout, load, countEn, rst);
input[7:0] din;
input load, countEn, rst;
output[7:0] dout;
reg[7:0] dout;
you must initialise the reg as an 8 element array
i think the syntax is
to actual declare the structure you define
here is a simple bridge code from 8 bit bi dir 16 bit data to 16 bit word bus
you actual have to declare the register structure
or its not valid and the compiler etc will throw one
here is a valid code block from a bridge code
to allow atari acsi 8 bit overword transfer to 16bit word syncro
to further allow coms with spi
youll find the full project on jookies site here
`timescale 10ns/1ns
module main(aDATA,bDATA,ACK,DRQ,INT,CS,A1,GotCmd,Do,Done,PIOnDMA,RnW, CLK, ClrCmd);
inout [7:0] aDATA;
input ACK;
output DRQ;
output INT;
input CS;
input A1;
inout [7:0] bDATA;
input Do;
output Done;
input PIOnDMA;
input RnW;
output GotCmd;
input ClrCmd;
input CLK;
>>>>>>>>elements of reg array these are initialisers also so set inital val
reg [7:0] rDATA;
reg mDo = 0;
reg rINT = 1;
reg rDRQ = 1;
reg rDone = 0;
reg rGotCmd = 0;
reg Hold = 0;
reg prevCS, prevACK;
>>> ie reg has 8 elements declared before posedge detect begin cycle
>>> mDo[0] rINT[1] rDRQ[2] rDONE[3] rGotCmd[4] Hold[5] prevCS[6] prevACK[7]
= 8 elements filled logicaly 0-7 as elements or array NODE'S
then you can compare the control register like as byte or nibble
ie 4 or 8 bit control struct
as registers are control structures ie msb 00000110 lsb
as is before begin routine change of the 'control' register
always @ (posedge CLK)
begin
if(!mDo && Do) // posedge Do
begin
if(PIOnDMA) // PIO
begin
rINT = 0; // the INT to L
rDRQ = 1; // restore the DRQ
end else // DMA
begin
rDRQ = 0; // the DRQ to L
rINT = 1; // restore the INT
end
if(RnW)
begin
rDATA <= bDATA;
end
rDone <= 0;
mDo <= Do;
end
if(mDo && !Do) // negedge Do
begin
rDone <= 0;
mDo <= Do;
end
if(ClrCmd) // clear Done
begin
rDone <= 0;
rGotCmd <= 0;
Hold = 0;
end
if((prevCS && CS) || (prevACK && ACK)) // if signal is H
begin
Hold = 0;
end
if((!prevCS && CS) || (!prevACK && ACK)) // if raising edge
begin
Hold = 1;
end
// if(!CS || !ACK) // if I should latch the data
// if(!CS || (!prevACK && !ACK)) // if I should latch the data
if((!prevCS && !CS) || (!prevACK && !ACK)) // if I should latch the data
begin
if(!RnW && !rDone) // write?
begin
rDATA <= aDATA; // from ST to AVR
end
Hold = 1;
if(!CS)
begin
rINT = 1;
end
if(!ACK)
begin
rDRQ = 1;
end
if(!CS && !A1) // if command was received
begin
rGotCmd <= 1;
end
rDone <= 1;
end
prevCS <= CS;
prevACK <= ACK;
end
assign bDATA = (rDone && !RnW) ? rDATA : 8'bz;
assign aDATA = ((!CS || !ACK || Hold) && RnW) ? rDATA : 8'bz;
assign INT = rINT ? 1'bz : 0;
assign DRQ = rDRQ ? 1'bz : 0;
// assign INT = rINT;
// assign DRQ = rDRQ;
assign Done = rDone;
assign GotCmd = rGotCmd;
endmodule
Added after 26 minutes:
input[7:0] din;
output[7:0] dout;
reg[7:0] dout;
reg d0,d1,d2,d3,d4,d5,d6,d7;
will work with no compiler error
