Uncertainty - how to arive at an Exact equation? (is it just skew + jitter + OCV )
hariharan.gb
Junior Member level 1
Bangalore, India, India
To my knowledge -
Uncertainty - the equation comprises addition of
( Jitter + Tool delta Uncertainty + skew (for prelayout) + OCV + few percent of wireload)
Assuming we can have a 5 - 10 % of clock for Jitter.
Can anyone please tell me how this skew is calculated, with clock as reference ?
Flat percentage of value we can have for skew, but then there is a formula to arrive for any skew. Can anyone share it?
OCV and wireload delay are meager value, which I shall raise a seperate discussion post :p
Hariharan GB
To add more for skew calculation:
Skew parameters comprises attributes like ( Rise/fall transition of clock, frequency parameter, Flip flop counts etc)
Can anyone get me a theoretical equation to arrive with all the above mentioned parameter to get a perfect skew calculation ?
Hariharan GB
Hi Guys,
Please help me., like how can we make a generic equation to skew, considering all type of clock frequencies.
Skew = x + y + z .... ?
Thanks
Hariharan GB
HI Hariharan,
Suppose two flops are there one is launch flop another is capture flop,
Clock Skew is defined as difference between clock arrival times between launch and capture flops.
What are the factors are involved for calculating the skew ::
In pll some jitter is available
from pll to clock root pin source latency + ocv effect
from clock root pin to flops network latency
now skew = (jitter + source latency + ocv effect +network latency (between clock root pin to launch flop/capture flop) - (jitter +source latency +ocv effect + network latency (between clock root pin to capture flop/ launch flop)
Latency values are calculated based on wire load models or real spef's based on which stage you need to calculate the skew.
Hope you understand.
Reactions: hjacky
    hjacky
