ic design interview questions
just be good in analog design , if you are fresh graduate then the interview will mainly measure your way of thinking other than deep technical background. so what you need is the basic analog design knowledge ( single stage amplifiers analysis , cascode , compensation for stability, .......etc ) and a good sleep and to be calm and show your ability to investigate circuits you never see it before i.e. elaborate your analytical capabilities & logical thinking
if you are expert then sure expect you will be asked about everything you did in details and a higher level of analytical & logical thinking should be shown!
good luck!
