typical application of "-add" option of create_clo
anjali
Full Member level 3
Full Member level 3
give me typical application of " -add " option of the " create_clock " in DC.
ami
Member level 3
Member level 3
VN
Re: typical application of "-add" option of create
Modifying the clock tree latency can have quite a big impact on the timing violations. If you 'd like to analyze your design assuming a different clock latency, it is possible to add an delay to the clock-source pin.
Regards[/code]
