muddasirwaheedmalik
Junior Member level 2
hi.
I am designing a 2 stage battery charger for my 48V lead acid battery 150A. The first stage would use ELTEK twin power plus rectifier set at 56.4 Volts with constant charging current around 50A (C/3). Now i need a circuit which senses the current reduced to 10A (as the batteryELTE termainal voltage rises) , i will then disconnect the ELTEK mains (through (SSR) and connect the mains (through SSR ) of smaller Eltek Flat pack rectifier set at 54V .Hence the two stage charging.
I have a shunt resistor which gives 60mv at 100A (60mv/100=0.6 mOhm resistane) by which i read charging current through panel type digital ammeter, 10A charger current will give 6mV , can i have any circuit which turns on/off a solid state relay by sensing current below 10A, or voltage below 6mv ?????
Regards
Regards
