tutorials for Graphic LCD
flashking
Full Member level 3
Hello
I am new to interfacing graphics LCDs with microcontrollers
I need books or tutorials for this
I am not limited to a certain microcontroller (anything will be good)
thanks
assasinsareus
Junior Member level 3
Hello,
Interfacing displays like the ones from 4D systems allow for a lot of functionality using simply serial commands.
Other more generic graphical LCDs operate with a matrix of 1-bit (monochrome) or 8 to 16-bit (color) memory locations per pixle. Normally to interface to a display you need to look at the driver chip being used and then get the datasheet for that as all of the commands and the signal timings will be explained. Its also good to get a piece of confirmed working source code for your display or driver chip as this simplifies the process.
engshahrul
Banned
Malaysia
I'm also want trying to use Graphic LCD. I found on internet many driver for Graphic LCD, but I did't buy any GLCD yet.
What is normal driver for GLCD and which is easiest?
vinoth8051
Full Member level 3
Delhi, Kanpur, Madurai, India
jignesh doshi
Full Member level 2
hello frnds,
i also want tutorial for Graphical LCD...
please attach some tutorial for it....
jignesh doshi
Full Member level 2
if i goes to open this link,i got notice like the web page is not available...
so please give me another link...
bigdogguru
Administrator
Southwest, USA
jignesh doshi
Full Member level 2
thanks bigdogguru...
now tell me one thing if i want to interface GLCD to 8051 base MC then can i directly connect?
jignesh doshi
Full Member level 2
ohk...
tell me any 1 GLCD which i can use in proteus and specify its details...
bigdogguru
Administrator
Southwest, USA
There are at least two KS0108 compatible GLCDs available in the Proteus libraries.
The specifications of the KS0108 are covered in the several of the tutorials I previously posted.
BigDog
jignesh doshi
Full Member level 2
ohk...
thanks a lot for guide me....
and one thing is there in proteus,TFT displays and TI's microcontroller are not available so any library for that?
youngyik
Hi BigDogguru,
Currently I'm doing GLCD model JHD12864E interface with Atmega32 prototype project(not with any Arduino's kit).
I wanna ask my GLCD model JHD12864E will be same as KS0108?
And is it compulsory install ProGFX software?
bigdogguru
Administrator
Southwest, USA
Yes, the JHD12864E has a KS0108 Compatible Chipset.
The first tutorial previously posted discusses the JHD12864E interface with an AVR:
Interfacing KS0108 based 128×64 Graphical LCD with AVR MCU
JHD12864E Graphics LCD
ProGFX is an AVR graphics library for KS0108 Compatible GLCDs, including the JHD12864E.
Handling Text and Fonts in ProGFX | eXtreme Electronics
BigDog
youngyik
Thx for your links.
But I'm not using any kit as shown as the link, there is error for my coding.
If I connected every GLCD's pins to Atmega32 pins, suppose need set for DDRA, DDRB and so on right?
In case I'm using external crystal 8MHz, can support for it?
jignesh doshi
Full Member level 2
hey guys please post circuit diagram for interface GLCD with 8051...
