Tuning Fabricated Microstrip Circuit
mdocampo1
Junior Member level 2
Philippines
I am curious if there is a way to tune a FABRICATED microstrip circuit?
I sent my design (9GHz oscillator) to a fabrication company. After they build its prototype, would I still have a way to tune the prototype?
If the impedance of a microstrip line is not the same with the one you designed (and getting a missmatch loss), there is an option to place some matching networks at its ends, and tune the circuit to compensate for the missmatch loss.
The problem that you get in this situation, the circuit becomes narrow band.
It could be a way, if you have thought about it during design. For example, a common way to tune an open stub is to place some unconnected small open lines at the end of the stub. they can be connected later in the prototype to adjust the overall lenght of the stub.
Another way is using small copper lines that can be cut and attached to existing circuit.
I hope it can help.
Mazz
thank you guys for the tip! im still waiting for my prototype :D
