TSMC Memory Compiler?
rakko
Full Member level 4
mozambic
tsmc memory compiler
How do you create ram based memories in TSMC flow. Other ASIC vendors such as IBM/LSI have a memory compiler you run to create all needed memory models and sizes for you. How is this done with TSMC flow?
artisan memory compiler
if u d/l the artisan tsmc lib, u can do it. they come with ram and rom generator. but these only work in sparc and hpunix platform
memory compiler
what exactly is the name of ROM/RAM generator in artisan library? can you be more specific?
memory compiler artisan
they're some separate files, not include in artisan lib.
tsmc memory generator
you can browse artisan's web site (**broken link removed**)
to get more specific information about the memory compiler
artisan compiler
I think RAM generator can be found in Artisan lib, but ROM maybe not.
synopsys memory compiler
yes they do have rom generator. i used that before.
typically they have
dualport SRAM
single port sRAM
ROM
2-port register file
do a search in their product and u can find them
memory compiler tsmc
anyone have login info for artisan site? user/pass
artisan memory generator
Using @rt1s@n's (or v$t...) free lib or tools need your company signing NDA with @rt1s@n... you can NOT download those files by just clicking in their web... :(
tsmc sram
the tool is RapidCompiler, it can generate parametered RAM and ROM. it's not a free tools.
+artisan +memory +compiler +types
I used @rtls@n's memory compiler before. I remembered it generated .lib model and needed library compiler in synopsys to convert that into design compiler DB format...It needed Java support on the Unix machine...
register file tsmc
who can share the memory compiler for linux?
how to use memory compiler
I suspect it was built on the Java platform, so if you install Java on your Linux, then
no problem running memory compiler...am I not right?
tsmc register file
Thanks. But it can't run on linux because it include some bin file for solaris.
artisan design compiler
Artisan provide memory compiler for TSMC.18 .15 .13 process.
SRAM, Register-file, high-speed, high-density.
I'm not sure are there ROM compiler.
artisan tsmc
Hi
The answer is unlikly negative.
The java part is for GUI Interface and swing support not for actual code generation. This part seems to be in native binary code for hpux and sparc.
You may try to find solution for migration from solaris sparc into solaris x86.
tnx
.18 memory compiler
you are able to create those files in command mode, not evoking the GUI.
currently i'm trying to edit the runscript to see whether it can be work in linux w/o the gui.
tsmc memory
You have 2 choices:
1) Make your own (study some VLSI and layout, then do your own layout)
2) Acquire a pre-designed/verified RAM-macro from an IP-vendor
There are several IP RAM/ROM vendors who target TSMC's foundry: Artisan Components, Dolphin Technologies, MoSys come to mind. Most TSMC customers use Artisan, because TSMC provides the Artisan design-kit at no (extra) charge -- all the customer has to do is sign an NDA and request the materials. Unless you have some special high-speed or high-density requirement (like e-DRAM or 1T-SRAM), then Artisan is good enough for you.
But you need to know exactly what you want. TSMC has many several different process-lines at each tech-node: general, low-power, high-performance, high-voltage, mixed-signal, etc. Each process-line has its own design-kit, and NO, the kits are not interchangeable.
For the "common" process-lines (CL013G, CL015G, CL018G, etc.), the complete Artisan kit has both RAM (1-port and 2-port) and ROM compilers. There are different types of ROM (diffusion, mask, poly), and availability depends on the process-line -- but every process-line has AT LEAST 1 ROM available.
Finally, a word of caution...If you just want to create a RAM or ROM of some size, and run it in your Verilog/VHDL functional simulation, then it's easy. You have nothing to worry about...But if you want to actually use the memory-macro to tapeout your chip, then there's a lot of work to go around. The Artisan memory-compiler has a lot of configuration options (top metal-layer#, power-ring width, etc.), and those are things your backend (layout) people need to answer. If you just pick any random#, you'll get a non-working tapeout...
Reactions: hbeck_
    hbeck_
artisan sram model
Hi
It is a good news to hear from a member.
We all are now waiting for your results.
If you could run the sparc bin files, you will overcome the problem.
tnx
Re: artisan sram model
Hi i tried all the process, I could able to generate the model, but how to include that in your original design. I am trying this Ip for or1200 as found in open cores. Step by step procedures, Plz welcome. i am struck at this stage.
Regards
lohith@37.com
Lohi21
