TSMC inductor HFSS simulation vs TSMC PDK
wufeng
Junior Member level 1
HI guys,
I am simulating a one-turn differential TSMC inductor with HFSS. The Q value from HFSS is dependent on the setup in the simulation. If I use guard ring as return path the Qmax will be lower and f(Qmax) will be higher. If I use a ground ring as return path, the Q max will be higher and f(Qmax) will be lower. Does anyone know how TSMC simulates or measures the differential inductor? Does they use guard ring or ground ring as return path? Thanks!
Wufeng
HI guys,
Wufeng
Hi friend, I'm facing the same problem when simulating inductor from PDK in TSMC. The Q factor is low unless changing guarding material from M1 to pec. It seems that the guard ring is not current return path. what do you think of if?
Do you deal with it?
