TSMC CMOS 0.18um DesignKit
amnon
Junior Member level 2
tsmc rf cmos 0.18um
Hi everyone.
I've installed the TSMC CMOS 0.18um 2.0v design kit on my ADS 2004A software
whenever I use one of the TSMC component for the simplest simulation ( for example, S-Parameters of R-C network) the simulator gives me this known error:
"R1 is an instance of on undefined model 'TSMC_CM018RF_BB_SUBCKT_mpo1' "
even when I enter the TSMC RF CMOS Process 0.18um.
does anyone familiar with this problem? could some one help me please? this is really urgent.
Thanks in advance,
Amnon
ads tsmc cmos
Make sure that the path to the model directory is correct. There are several ways to do so. I do not have the software availbale at this time, so I cannot guide you in details. - Good luck
tsmc 0.18um designkit
make sure the tsmc rf cmos process is on the top view of your design.
tsmc 0.18um model files
hi,
i encounter this same porblem in cadence. even if ur model file is set correctly, it caused me this error. wat i did was to solve this was I went to the menu "Tools --setup corners "in analog design environment window and clicked "save model file". Then it worked fine for me in cadence. See if can u do a similar thing in ads. sorry if u havent worked with cadence.
cmos 0.18 um process
hi, everyone
I encontered the same problems, someone could solve this probolem?
thanks in advance
cmos 0.18 tsmc
I encontered the same problems!
Hope somebody can help us!!!
0.18um cmos tsmc
hi,
can every bady send me the TSMC 0.13µm Design kit for ADS?
thinks
