pradhan.rachit
Full Member level 3
Hello experts,
I have been building a Voltage Controlled LPF for audio applications and have problems in troubleshooting the circuit issues.
In the above circuit, I've applied a 0.2Vpp/500Hz sine wave at the input port. I'm getting the signal at point A, but it fails to be present at point B. I tried to isolate the fault by removing each resistor next to it and noticed that the signal is present after R8 is removed from the circuit.
Also connecting the 20k resistor next to it causes the signal level to fall a bit.
Could someone help in explaining the working of the circuit? Also possible measure to be taken to rectify this problem.
Thanks!
PS : IC1 is LM13700
Thanks!
PS : IC1 is LM13700
