kazim
Member level 4
- Joined
- May 26, 2006
- Messages
- 77
- Helped
- 6
- Reputation
- 12
- Reaction score
- 3
- Trophy points
- 1,288
- Location
- Nowshera, Pakistan
- Activity points
- 1,838
the circuit that needs to be switched (I'll call it circuit "A")
It is in between two pins of a larger circuit, so the "negative" pin (following current flow from pos. to neg. ) , is *not* grounded -- it goes back into the circuit.
how can i use transistor in it to switch it on and off.
i cant find any circuit i which transisto as a switch does not use ground
