darryl_co
Member level 1
How do I calculate the power flowing through the transistor. Should I take Vcc*Ic or Vce(sat)*Ic. Vce(sat) as in mentioned in the Datasheet of a transistor. If instead of a relay it was a resistor and input was a square wave signal, does the calculation remain the same. Sample values would be Vcc 35 VDC and resistor value 2K2
