Transistor Matching Concepts
VLSI Bravo
Junior Member level 3
can anyone help me to get a clear cut idea of matching concepts (interdigitized and common centroid) with examples.
any documents or book to go through...
thanks in advance.
Hi..
you can study a lot about matching through googling.. anyways refer these books..
Art of Lyout by A.Hastings
Cmos ciruit design,simulation and layout by Jacob R. Baker
refer these PDF's too
  • Layout02.pdf
  • Common_Centroid.pdf
Books:
1. Alan Hastings "Art of analog layout"
2. Baker, Li, Boyce "CMOS circuit, design, layout and simulations"
Articles:
Any papers about current steering DACs, e.g.:
1. C. Bastiaansen, D. Groeneveld, H. Schouwenaars, H. Termeer "A 10-b 40-MHz 0.8-um CMOS current-output D/A converter." IEEE Solid State Circuits, vol. 26, no 7, 1991, pp 917 - 921
But in briefly example of two transistors:
1. Interdigitized:
ABAB
2. Common centroid:
ABBA
In common centroid the transistors placement is around one point of symmetry, while in interdigitized are alternately (layout of multifinger fet is a good example)
hi guys, a help in transistor matching,
common centroid matching for 5 devices
A=4, B=256, C=20, D=20, E=640
can any one match this devices in correct pattern, hope for a soon reply
i am expecting some help guys
If You won't try by yourself, You will never learn ;-)
If You make a 31x31 matrix, a A device should be at corners, C and D 5 per quadrant, B every 4 devices and rest place for device E and dummies.
