Transformer primary winding question
neazoi
Advanced Member level 6
Greece
Hi, This is the picture of a mini magnetic amplifier (called ferristor).
If one would want to build the ferristor, how he should wind the left hand side windings?
My guess is that the left winding, must be two with different phase (wind opposite) so that they can cancel the transformer action from the output winding.
So how to wind them?
A guess is to start with a pair of magnet wire and start winding it into the core. The beginning points of this winding will form the top and bottom points of the left winding.
When finish the winding, connect the other ends of the wires together. This connection is the connection of the two left windings at the center of the ferristor.
Does this makes sense or I got it all wrong?
Then you will always see zero output. They are wound in the same direction. The permanent magnet provides some bias so that the core is working in the linear region. The magnet must not saturate the core (nor the signal).
The two ends of this winding will form the left side of the coil seen in the pic.
You need to have another set of coils, just like a regular transformer. Only the core should be different.
well, I have never heard about ferristor but that is my understanding from the diagram you provide.
Reactions: neazoi
    neazoi
