Toll collection system using pic16f877a
Sunny55
Full Member level 3
Hi, i am new to PIC programming. I am doing a small project on "toll collection system" using PIC16F877A and Hi Tech C compiler.
I have think of the codes in the normal C language but does not know how to convert it into the Hi Tech C compiler language. I have also no idea on how to start writing the program. Can anyone help me please?
Thanks alot.
Sunny55
Sunny55
Full Member level 3
Hi internetuser2k12, thanks for your reply. The system works with the user pressing three switches which indicates three entry locations.
When a user presses a switch, it will also ask the user to enter the card amount and then the system will display the distance travelled, total fee to pay and also the calculates and displays the card's balance after the payment.
After the payment is done, a green LED will turn on indicating that the driver can leave the toll.
How does the card amount entered? with 3 buttons or keypad? Does it includes a card reader?
Which PIC do you want to use? Post your code.
Jestin_cubetech
Advanced Member level 1
you can implement a toll collection system using RFID tag Reader,RTCDS1307 and LCD16x2.
Sunny55
Full Member level 3
Hi, I am replacing RFID reader using three switches.
Hi all, the card amount is entered using the keypad. The card reader is replaced by the use of the three buttons.
Regarding the code, i do not know how to write the coding but i have the idea.
First, LCD display ("please press a switch"); - Switch 1 : location 1, switch 2: location 2, switch 3:location 3
example: if user presses switch 1: he entered the highway from location 1.
Then, printf ( "pls enter card amount:"); - to ask user for card amount.(using keypad)
// If fee is $20 and user enters $30, balance is calculated ($10) and display
else if fee is $20 and user enter $10, printf( " pls top up card");
The toll rate for location 1 is $30, location 2: $20 location 3: $15
Then
printf( " the distance travelled is:);
printf( " the total fee is :);
printf("the card balance is:);
the green light turns on; - toll paid.
else
red light on - indicating error.
I hope you can understand my idea. Thanks.
printf( " the distance travelled is:); cannot be printed on lcd. It is more than one line. Do you want to use PIC16F877A and 20X4 LCD? or do you want to use 40X4 LCD?
Sunny55
Full Member level 3
Hi, i think we can just print("distance:"); . I am using PIC16F877A and 2x16 LCD display. Thanks.
Hello!
How can you print 3 lines in 16X2 display. you have these 3 lines
Can you use this circuit?
What are the 3 distances?
Sunny55
Full Member level 3
Hello!
Hi internetuser2k12, thanks for the circuit provided. The keypad i am using is a 4X4 keypad. Could you provide me with the complete Hi Tech C compiler coding please?
The three distance are as follows:
Example: Distance from location 1 to destination 1: 70KM, Distance from location 2 to destination 2: 50KM, Distance from location 3 to destination 3: 30KM.
I haven't used Hi Tech C much. I don't know how to code lcd routine in Hi Tech C. Can you tell me how to do that. I use mikroC. In that you won't get code for LCD routines. It is a hidden library. There is no 4X4 keypad in proteus so I am using 4X3 keypad, but I will code for 4X4 keypad. why do you need 4X4 keypad. What does the keys do? each key.
Sunny55
Full Member level 3
The program in mikroC and the 4X3 keypad should be fine. Could you provide me with the complete program code using mikroC please?
Thanks alot
Sunny55.
Thanks alot
Sunny55.
Do you want to use 4X4 keypad. What are the 16 buttons represent?
Sunny55
Full Member level 3
Hi internetuser2k12 , i found this page: https://www.edaboard.com/threads/21885/
We can learn from the codes here too.
Hi, Yes, i would like to use the 4X4 keypad. The 4X4 keypad is used to enter the digits like when the system asks for the card amount, the user will enter the amount by pressing the numbers on the keypad.
0-9 is enough. why do you need 4X4. what are the other 6 buttons do?
I have written some code, but my compiler is creating wrong hex files. Can you compile the code in mikroC and simulate it in proteus?
Can you use 20X4 LCD?
Sunny55
Full Member level 3
I have a 4X4 keypad but i can just provide the connections for running the digits.
Yes, Can i have the codes please?
For the LCD display, i only have a 16X2 LCD display.
I wrote a code but its not working properly. I will write a new code from scratch. Please wait.
Sunny55
Full Member level 3
Hi internetuser2k12, is the code ready ? I would like to test it with my circuit. Thanks alot.
Ther is a small problem. Do you want the enter key to be pressed after entering the amount so that the amount gets registered?
There is a small problem. Do you want the enter key to be pressed after entering the amount so that the amount gets registered?
Also tell me the values of the keys. 0-9 is used for 0-9 but the other 6 buttons?
