maark6000
Member level 5
I'm having some issues with power supply noise, I'm working on something that has both digital and fairly sensitive analog circuitry, so I am trying to separate the analog and digital components from each other as much as I can. One weak point seems to be the DAC0808, especially with it's strange power requirements (+5 / -15). My analog side exists between +/- 15 v. rails, and then the digital side is just +5v and ground. The problem (at least in my mind) is that I feel like the DAC should really exist in the analog realm, but with it's need of a +5 Vcc, is obviously tempting to just grab that from the +5 rail. This seems like a bad practice. To me the alternative is to find a DAC that can be supplied with my analog +/-15 rails. So my question is what DAC's do you guys use?
I should point out in advance that I am using a "star" ground approach, my digital and analog sections meet at a common power supply point.
Thanks!
Thanks!
