lhlbluesky
Banned
i want to ask a simple question,for a pipelined adc,the odd and even stages work in non-overlapped clock phase phi1 and phi2,if the odd stages(for example,the first stage)work in phi1 phase,then the even stages(for example,the second stage)work in phi2 phase,but what phase do the sub-adc(comp) and sub-dac of the odd and even stages work?i think sub-adc(comp) and sub-dac of odd stages work in phi1 and phi2;and sub-adc(comp) and sub-dac of even stages work in phi2 and phi1;is that right?
if so,i have another question,when i simulate the first and second stage using vdc source separately,they work well;but when connect them together,the second stage
can't work well,the output of sub-adc is always 01 in the full range(10 bit 1.5 bit per stage);when i simulate the sub-adc with vdc source,it works well,too;confused.
the first stage works well ,i think this is because i use vdc source in the first stage,but the input of the second stage is the output of the first stage,and it has a process of settling;but when does the sub-adc(comp)work for the second stage?
really need help,thanks all for reply.
thanks.
thanks.
